UKadventurer
Continuing the topic of winter life in the mountains in a 'ger' (yurt), I thought I'd add something about clothing.
As a holiday present my wife had a winter 'deel' made for me. It's a traditional robe worn by Mongolians for eons. I got the winter one, lined with sheepskin. It can be made with lambskin but it costs 2x more. This cost US$230 custom made for me.
Pros: Subjectively it looks pretty badass. It's very long and will cover my boots. You can just throw it on right out of bed and go outside.
Cons: it's freaking heavy. It's made of sheepskin, not just the wool, plus the outer textile material. The weight is 4.5kg (10lb) and you feel it. Not very well sealed from wind which can blow underneath. Not as warm or as light as a down parka but more durable. Not as flexible as a parka and a bit of trip hazard. The sheepskin is still stiff. I hope it breaks in.
Typically I've been a fan of down mountain parkas from way back in the UK, USA and in recent years in Mongolia. I've got 3 now. My go to parka is a Rab brand (UK company) which I got cheap second-hand from my nephew who lived in Mongolia and then left. I think I gave him about $50. I've done tons of mountain climbs or just city walks to work. I still use it if it's not awfully cold.
Pros: it's pretty warm but requires layering if it's colder. Decent for hiking when you don't want to overheat. The hood covers part of your face too. It's light and highly compressible.
Cons: it uses a light fabric which is prone to cuts and tears but can be patched if not too bad. It uses sewn-through panels which causes some cold spots.
I always have a wool and fleece hat. If I'm going to climb an exposed mountain, I'll take dual-lens goggles because the wind chill is killer. In the next photo it was only -25C but there was a high wind. I needed to cover every bit of my skin. A fleecy balaclava is also essential to cover everything the goggles don't cover.
I recently got some locally made boots for about $90. I wear them on the daily. They are cowhide are fully lined with fur. Dog fur, I think. This photo also shows my fleece leggings which I usually wear under jeans or work pants.
Pros of the local boots: slip on, very warm, socks are optional, good lugged soles.
Cons: They wouldn't be a great choice for hiking far. They are a bit loose and can't be tightened much at all. Snow gets in unless I put my pants over the boot.
If I'm going hiking, I'll wear some Columbia winter hiking boots which use synthetic insulation. "Thinsulate" maybe and a reflective lining. For snow, you'll want a gaiter to seal out the deeper snow.
In preparation for moving to the mountains, I decided to upgrade my old down parka with higher performance Rab mountaineers parkas. They have a higher loft filling and use box construction instead of sewn-through, so no cold spots. Also I got one for the wife. They cost about $370-400 new.
Pros: extremely light and compressible. Extremely warm. Good hood with some face protection. Perfect for all day or night outside activities.
Cons: the nylon is even lighter than my previous jacket and can be snagged, torn very easily. I have to be careful what kind of activity I do. Construction is out of the question. Sometimes too warm and I don't think I'd hike in it but I'd probably pack it in case I need it.
Finally, to gloves. I don't have anything mega special. I generally wear some cheap wool and fleece gloves. An overglove can be added if I'm out for a long time and/or it's very windy. Generally, I just put my hands in my pockets if they get too cold, if possible.
My daily gloves are the cheap (about $10) wool and fleece lined ones in most photos. These are adequate for a short time.
The Columbia winter gloves came with fleece liners but I'd probably swap them for the wooly ones and liners if it got extremely cold and windy.
This is how they originally came:
But I've found this a better combination in the worst of weather:
I bought some electric glove liners but one has failed already. I'll try to fix it because there was some merit to this method with an overglove of course.
Regarding socks, I just use hiker socks (smartwool, etc) or some heated socks I got last year. Nothing special to say about those. The heated socks are pretty good when inactive but for hiking they'd probably wear out too quickly. Wool is better for hiking.
For me, my hands are the most vulnerable. Then feet. I'm almost never cold in my core area. That's probably pretty normal for humans but my hands get numb probably sooner than most people. I may buy some locally made fur mittens. The winter is far from over.
