08-25-2014, 07:47 PM
#2
Re: Wind blown snow under center dome
Is it possible to 'pinch' the yurt cover between the dome (on the outside of the yurt cover) and a backer you add underneath the dome frame, inside the yurt, and under the cover?
The idea is similar to pinching fabric between your fingers. You'd screw the backer into the dome frame from inside the yurt, thereby trapping the yurt fabric between the two in the process. Lay a fat bead of silicone on the appropriate surfaces during assembly and there will be no leaks at the screw holes.
Another idea is to remove the dome, and attach a fabric skirt to the inside of the dome frame, using a similar 'backer' technique as described above. Reinstall the dome with the skirt draped down over the yurt cover. Then, add an two backers of the same dimension, one outside and one inside, and pinch the two layers to eachother. Silicone and screw as above.
Just a couple ideas. I've done the 'pinch' technique to tarps, and sheeting, to secure fabric tight to a framework. a few times. It works very well. No rips, no flapping. Good and solid attachment.
