01-08-2015, 09:24 AM
#27
Re: Yurt Dome Insulation Install and Condensation
Well, I have a 30' Pacific yurt (hunting camp) with the same reflectix insulation, no insulated floor, no ceiling fan and no other insulation other than weatherstripping between the yurt wall and the skirt. I have been up there when it was -20 and walked around in a tshirt and shorts.
It sounds to me an issue with your heating solution. A pellet stove will not work well in a yurt because most of them are forced air heat, not radiant. So you might as well get rid of that. You would be better off getting a larger wood stove instead.
Did you partition your yurt or is it all open?
