Yurt Dome Insulation Install And Condensation
Old 11-25-2013, 02:39 PM   #31
Default Re: Dome Insulation Install and Condensation
It's starting to get cold here (well, it is Sweden after all) and we too are working on winterising our yurts. After the last gale off of the North Sea we realised that we had to do something to improve the
. You could actually feel the wind 'stealing' the heat from the yurt.
I think we could have left the yurts the way they were but the amount of wood we would need to keep them warm seemed like a bit of a waste. So we've started to experiment with relatively low cost solutions.
We've had a lot of success with EarthWool. We've simply tucked sheets of EarthWool between the rafters supports and hung a cotton liner in front of it. Total cost for insulating the walls of the 24' yurt was about €140.
We have no condensation problems and the air quality inside the yurts is excellent. We haven't insulated the roof (yet).
We did initially test with putting some builder's plastic between the EarthWool and the inside cotton liner, but discovered that condensation soon formed between the EarthWool and the Reflectix. Once we removed the plastic everything was fine.
dlhall likes this.
Old 11-25-2013, 04:25 PM   #32
Stephan,
That is a good point. Perhaps those here who are trying the roof
, did not cover it with non-breathable materials like foam board, plastics, etc, it would help with condensation? I like the idea of a cotton liner, that might work perfect in conjunction with the
being cracked open slightly. It allows the water vapor to escape.
Old 01-12-2014, 12:38 PM   #33
Well, the attempt to seal the cracks did not work - it's still dripping inside and we stopped all
- creating activities that we could. At this point I would not recommend anything other than fully breathable insulation (natural fibers) inside a yurt.
And the rigid foam is nasty about filling the air with plastic particles when cut. It isn't too bad once secured in place though, but I would not do it again. I wish it hadn't been recommended to us, but we are toasty warm...
I will keep you all posted about our future attempts to remedy the problem. We are talking with
to see if they have any ideas or can find someone who did this successfully. If anyone else does use rigid foam adn it doesn't drip, maybe with a
barrier on the inside? Please post details!
homesweetyurt is offline   Reply With Quote
Old 01-18-2014, 04:09 PM   #34
Default Re: Yurt Dome Insulation Install and Condensation
I was just working on the yurtinfo.org makeover, and came across this place:
Bonded Logic - Construction Products - UltraTouch Denim Insulation
They have a few different types of insulation that might be helpful.
Old 12-30-2014, 04:59 PM   #35
I also have this issue. I live in Ely, MN where winters are quite frigid. My yurt (Pacific Yurts) is completely insulated (5.5" foam under floor, 2 layers of Bonded Logic denim insulation in walls, and 5.5" foam between 2x6 rafters). The inside humidity level stays between 32-45% yet I still get abundant ice build-up and dripping on the
. The water runs down on top of the foam. I'm also worried this will cause mold and rot. I have considered installing window plastic under the dome to reduce heat transfer and condensation. Has anyone else tried this? I wish one of the yurt companies offered an insulated glass dome.
Matt is offline   Reply With Quote
Old 12-30-2014, 05:02 PM   #36
I wish I knew the answer.. I think at some point though, a winter dome will need to be developed that allows the yurt to vent. Just my opinion though.
Old 12-30-2014, 06:37 PM   #37
We placed a vapor barrier to cover the ceiling this fall and it appears to have reduced our ice build up. We still have dripping in a few places though - most noticably above our door. This spring we will remove the exterior side wall and check for moisture and mold in case the vapor barrier is just channeling the water down into the walls now instead of allowing it to drip all over our house.
I have felt the top of the wall insulation in a few places though and it seems fairly dry. We will post our results this spring in the hopes of helping others with this problem.
Also, we attempted some ventilation, but a yurt just isn't designed for it. We tried to vent above the door with some pipes put above the door fame into the roof and leaving the dome open, but with no visible improvement. Our current experiment is to seal as much of the roof off from interior moisture as possible. We will let you know our thoughts after this winter.
Old 12-30-2014, 06:38 PM   #38
And Matt - we found that having the dome open whenever we are cooking or bathing also helps so my initial thoughts are not to seal it off. Anything is worth a try though - please report back if you find any good solutions!
Old 12-30-2014, 06:41 PM   #39
I am wondering if a dome could not be modified with PVC to allow ventilation, and then the dome could be replaced during summer months?
Old 12-30-2014, 11:14 PM   #40
I'm very impressed with the lack of condensation in our yurt. Yes, we get some......2 adults showering, cooking, laundry drying, tracked in snow melting, etc but not bad at all.....the dome is open just enough to slide my hand in and has been all winter. We heat with wood & infloor
. There are times the windows fog up but then it dissipates ..... What I think truly helps is I didn't mess with the way my yurt is designed to work. Despite the fact it's carved up into rooms no interior wall is attached to the exterior.....4 inch gap, same as around the floor of the loft. Air naturally moves by convection and moisture vents out the dome, it might take a bit of heat but who cares? The infloor
is set to keep yurt at 50F when stove goes out and that constant slow heat dries out tracked in snow and laundry hung in bathroom to dry is dry in 24 hrs. I'm sure that leaving my yurt alone by not sealing things up or covering with plastic etc really helps. It's not sealed up real tight and all 6 windows are just zip out clear vinyl. It just all works great! No moisture build up anywhere & no mold or musty smells.
colorado yurts, dome, insulation, moisture, yurts of hawaii
