Yurt Dome Insulation Install And Condensation
Old 11-15-2012, 10:20 AM   #1
Default Yurt Dome Insulation Install and Condensation
We have the factory
for our
, but we have 2 issues -
1. The metal crank rod that enables the
to open and close gets in the way from sealing the
onto the velcro completely. Is this supposed to be removed to use the insulation on the dome, or should we cut a hole in the insulation so the rod can poke through?
2. We are
with a wood stove and just this AM there was dripping from the dome (insulation mostly on except where the rod prevents it). I pulled the insulation off and there's so much condensation up there it is starting to drip. How can we avoid this happening?
colorado yurts, dome, insulation, moisture, yurts of hawaii
