Wood Stove Type And Size
Old 08-27-2020, 09:28 AM   #1
Default Re: Wood stove type and size
Wow! Thank you! This is my first post on any forum and you just saved me a month of worrying! How is this stove as far as draft needed? My pipe will run straight up from the stove and exit in the center of the yurt. I’m guessing the pipe will be about 14-15 ft...
Clarky is offline   Reply With Quote
Old 08-30-2020, 05:46 PM   #2
The longer the pipe, the better your draft will be. Mine goes through the wall and has a pretty good draft.
If you are going to put it into the center then you may not need the heat shield.
My brother and I just cleaned out the chimney this weekend. It is starting to get cool here.
