Tankless Water Heater Recommendations
Old 05-04-2020, 07:33 AM   #11
Default Re: Tankless water heater recommendations
Yes, here is the heater and pump separately:
https://amzn.to/2Ywm2Ad
https://amzn.to/3b3lSTM
Old 05-06-2020, 02:16 PM   #12
Thank you so much for the speedy reply. Do you have your yurt somewhere it freezes? That's the water heater I was looking at initially but we would like to use it inside, do you use yours outside? Trying to figure out a safe way to use a propane tankless inside (not sure best way to vent to outside) where we can just use a hose really. Seems like these would be perfect except they say to use outside.
alyssam is offline   Reply With Quote
Old 05-06-2020, 03:08 PM   #13
Yes, it gets down to -35 here in the winter. I used it inside. When I am not there (it is my camp, not my home) I put non-toxic RV antifreeze in it.
Old 05-08-2020, 01:12 PM   #14
do you vent it or did you just hook it up inside? thanks!
Old 05-09-2020, 05:19 PM   #15
I just hooked it up inside. The longest it runs is about 1 minute when I fill up the sink to do dishes. I have another in our shower yurt and I usually run that with the door open.
Old 10-18-2021, 07:46 AM   #16
ECOTOUCH ECO55, I would recommend this water heater to anyone. Installed for my shower in our little house and it amazes me how well it works. I mounted it under the building near the shower and operated remotely through the floor.
johnsonrdn is offline   Reply With Quote
Old 10-30-2021, 08:33 AM   #17
It uses 220 volts instead of propane and only heats water as needed as required. Overall I am very impressed.
