Real Walls In A Pacific Yurt?
Old 11-18-2022, 06:30 AM   #15
Default Re: Real Walls in a Pacific Yurt?
Originally Posted by pablo View Post
I don't think vents in the walls would be necessary. At least not in our climate where it is very windy. The wall fabric is loose enough that air moves through the walls quite well. A little too well. We went around and caulked the bottom of the drywall where it meets the floor, because it was too drafty in the winter. We also did some caulking around the windows. As I mentioned before, we have seen some spotty condensation here and there in the wall insulation, but none that has spread or moved into the drywall and our air quality seems good. Caveat: we live in a low humidity climate east of the Cascades. Make sure you have an exhaust fan for the kitchen and bathroom and/or crack the dome. We still plan to replace our wall fabric with hardy board, but have been delayed in that part of the project because of COVID prices, etc... In the mean time we have a very thorough fire break built around the yurt!
Hi Pablo (and the entire forum), I've looked through your pics of insulated walls and sheetrock finishes in your yurt. Looks great! We've lived in a 35'
Shelter Designs
yurt in Upstate New York (in the Adirondacks) since July '19. Temps in the winter routinely drop into the negatives. We have three different heat sources including our primary, a good woodstove, so there's no problem keeping things warm but I've always been disappointed in two things: insulation and mold around the sill. When they built our yurt, they screwed up the fabric cut on the skirt, making it too short so the insulation doesn't come down below the finished floor height. This creates a cold area that creates mold in the winter. I am frustrated with it and would love to create walls and ceiling assemblies that meet at least the minimum code requirements for insulation. My questions to Pablo (and anyone else who has experience with insulated yurt wall and ceiling assemblies are;
1. Are you happy with the wall assembly? Does is cause any
buildup or is the dew point further out towards the exterior so no condensation on the interior?
2. What type of assemblies have been used successfully? I've read through posts about hardiboard but thinking something like (from outside to inside) Hardiboard + WRB + 3/8' OSB plywood + Rockwool (or sprayfoam @ 7R/inch x 5") + 3/4" T/G pine. VERY CURIOUS TO HEAR PEOPLE'S THOUGHTS ON THIS!
3. Ceiling: We have 2x12" rafters to achieve the required snow loads. Has anyone used rockwool or sprayfoam or other? It would be great to cover the ceiling with something impervious (smooth/hard) like wood or drywall; something that is able to be cleaned. Has anyone done this?
4. Roofing: I've heard of people contracting with companies that retrofit old grain silos with metal standing seam roofs. I'm contemplating this approach. If possible, the roofing company would calculate all of the angles and custom cut panels so then it's just about installation. I'm concerned that using conventional standing seam panels and cutting them to match the contours of a conical roof would result in a massive amount of waste. Has anyone successfully put a metal roof on a yurt?
Sorry for the long post. To all of you; thanks for posting and looking forward to hearing any and all comments/feedback!
LCBailey is offline   Reply With Quote
pacific yurts
