Lighting In The Yurt
Old 06-26-2012, 05:23 PM   #1
Default Lighting in the yurt
We are still working on the lighting at the yurt. Right now we get most of the light from a couple small lamps that have real small 9 watt CFL's candle bulbs in them. They throw off quite a bit of light and most of the time, that is all we need. I do have a couple other lamps with regular size CFL's that I will also be using once I get the larger inverter. With the yurt being wide open and not divided in any way, a little bit of light goes a long way! Here is a shot of one of the windows with just two of those candle bulbs going:
I still have a bit of work to do though and it is a constant battle when it is a camp. You never seem to have enough time.
Peacefirst likes this.
Old 09-23-2012, 04:22 PM   #2
An uncle of mine maintains commercial signs in the city he lives in and many of them run on LED lights. Eventually the signs are changed or the lights are replaced. He just sent me a box of the used ones they were going to throw away. I hooked them up to a 12 volt port I have on my battery bank and they work great! These things barely use any power but they light things right up. My lousy camera doesn't show it as good as a better one would bu you will get the idea.
Here they are as I put them up:
This is where I put them on the ring:
Hard to show how much it lights everything up, but here you go:
Old 09-23-2012, 04:32 PM   #3
bss
That is cool. I have LED rope lights running all the way around at the top of the khana in my yurt.
Old 09-23-2012, 04:32 PM   #4
Would love to see a pic of that!
Old 09-24-2012, 01:17 PM   #5
Dan R-M's Avatar
It's good to know people huh? That is one awesome source of light.
Old 10-05-2012, 12:18 PM   #6
bss
Here are a few pictures. It's more ambient light than functional, but has a good feel when you're relaxing reading a book or something. The spot over the door where there isn't any light is the beginning and ends of the rope light. They don't quite go all the way around.
ID:	204   Click image for larger version
ID:	205   Click image for larger version
Old 10-05-2012, 12:29 PM   #7
Now that is cool. How much power you figure they use?
