Is This A Good Wood-stove Trick?
Old 05-21-2013, 11:56 AM   #1
Dan R-M's Avatar
Default Is this a good wood-stove trick?
Or just a creatively bad idea?
I'm thinking about the concept of putting a woodstove under a loft in our yurt design. That way, if it were really cold we could curtain the loft area in for sleeping and not worry about
the whole space. Assuming a good amount of head space, say 6 feet, this isn't dangerous, right? Is there something else I might be forgetting?
Old 05-21-2013, 01:53 PM   #2
Default Re: Is this a good wood-stove trick?
Well I know in most places, code doesn't allow for a combustion heater of any kind in a bedroom. (With the exception externally vented gas fireplaces that is). If you want my opinion, it sounds like you are asking for trouble. Keep in mind that heat rises so a loft may be a bit warmer than the floor area naturally.
