09-09-2014, 10:03 PM
#68
Re: Insulation
Based on my experience you'll need a massive wood stove to heat a 32' yurt. Look only at the biggest model a manufacturer offers. Plus, the more mass the stove has, the better.
I have a small 'fireplace insert' type welded steel wood stove with a dinky little firebox maybe 1.5 cu ft. When it is well below freezing that little dude barely heats my uninsulated drafty 16' yurt. At zero it just doesn't heat it, period, unless full on wide open and stoked every fifteen minutes.And, with a drafty porous canvas wall, the heat exits pronto.
That's why you need a tight yurt that is well insulated if the temp dips to -30. Frankly I would consider a forced air system to keep the yurt warm. But expect to pay $$$ for heat. Yurts are great, but they aren't houses.
