How To Circulate Heat In Large Yurt
Old 09-29-2019, 01:19 PM   #1
Default How to Circulate Heat in Large Yurt
New to yurt living. I'm wondering how to circulate all that luscious warm air the wood stove creates and pillows up against the ceiling.
The yurt is large, insulated, wood framed. 33' diameter. It's a house. With a loft.
Ideas... experience.. links... ?
What's the physics of all this... the basic principles?
Thank you Much!
-Ralph
rchaney is offline   Reply With Quote
Old 09-30-2019, 08:29 AM   #2
Default Re: How to Circulate Heat in Large Yurt
Basically, install a ceiling fan.
Old 09-30-2019, 02:54 PM   #3
yup a fan is THE basic temp destratifying tool in large open areas. You can also just point a floor model up at the ceiling and get it destraitified.
Old 09-30-2019, 02:59 PM   #4
There are also non electric fans that sit on the woodstove, that are designed to help circulate the air. Never used one or seen one in use, so how well they work beats me. I'm gonna guess in a big yurt that size they may not do a whole lot of air mixing. Probably worth investigating online though. Good luck.
Old 09-30-2019, 03:02 PM   #5
We have ceiling fan in our master bedroom that blows down or up and really mixes the air. I worked on several simple log cabins up in WY that used ceiling fan to destratify woodstove heated air in the great room. Work GREAT. Otherwise an oven up there.
Old 10-01-2019, 01:05 PM   #6
Thank you much! I'll try a floor model, pointed up... and also experiment.
-Ralph
Old 10-03-2019, 09:49 PM   #7
the stove fan, and the ceiling fan is the best, but if you use a ceiling fan do not put it under the
unless you want a strobe light when the sun is out I would suggest two ceiling fan to circulate the air better.
Old 02-05-2020, 11:35 AM   #8
Does anyone have experience installing a ceiling fan in a yurt? I'm considering one for my 20' and 24' yurts for warm air circulation in the winter time.
dickinson is offline   Reply With Quote
Old 02-05-2020, 02:14 PM   #9
If there is 8' of headroom from floor to fan blades you will be OK. A 2x10 screwed flat between a pair of rafters will hold the fan nice and solid. The shorter the base to fan drop tube, the less wobble. Base of a typical fan is 6" wide. The junction box requires ~4" hole. Oscillating floor fan(s) pointed at roof will also mix air. And not violate any codes either. Good luck.
