Costs Of Heating A Yurt
Old 10-13-2016, 07:08 AM   #1
Default Re: Costs of heating a yurt
Looks pretty sweet! Do you happen to know someone who uses a ventless propane heater? Curious about costs of running it.
katherines3 is offline   Reply With Quote
Old 10-13-2016, 10:59 AM   #2
You're best bet for getting annual propane usage is probably to call up the nearest propane delivery service and ask them. Yurts run a bit colder so you might use roughly the same as a typical house (bigger but better insulated). You have the cost of getting a tank (5-500 gallons) plus filling it up however many times a year (once or twice if the tank is sized correctly). Propane costs vary a good deal by region, season, and year.
Old 10-13-2016, 05:47 PM   #3
If you are just talking about using it to keep a 24 yurt warm between wood stove fuelups (while you are away), I bet you could get away with a 40 pound tank every month or two. Here, that is about $25 to refill right now in NY. I had a friend who used to run one for supplement heat in a back room of a bar he owns. He went through a 20 pounder every 2 weeks in the winter, but that was the ONLY heat there was in there at night.
Old 10-17-2016, 10:03 AM   #4
Thanks for that!
