Cold Weather Report 2017
Old 01-06-2017, 08:12 PM   #21
Default Re: Cold Weather Report 2017
Well how about them apples. Never seen onea those. Very nice.
Old 01-07-2017, 12:25 AM   #22
Stea's Avatar
You should get a metal wood ring. You can usually find them at yard sales or on Craigslist. I got one for my camp for $5. Keeps the wood off the floor let's you store more inside.
Example:
Attachment 955
Good idea. I'll keep a lookout for one
Old 01-25-2018, 01:31 PM   #23
Hierony, I put the that foam weatherstripping between my walls and platform before I screwed the wall to it. That helped a lot with draft.
I believe it was 1 inch foam.
We have just ordered a 32' yurt from
Yurtz by Design
. We live in Northwestern Ontario, and plan to live in the yurt. We will be using foam
in the platform, but I am wondering if we should also install foam weather stripping between the walls and the platform to eliminate any drafts? Thanks.
Swykes is offline   Reply With Quote
Old 01-25-2018, 05:03 PM   #24
I did that on mine and it does help. If you are going to use a wood stove, one of the big things you can do is to vent combustion air from outside.
Bob Rowlands and Swykes like this.
