Can Anyone Help Us With Advice Please As We're Having Problems In The High Winds
Old 01-11-2015, 10:33 AM   #1
Default Can anyone help us with advice please as we're having problems in the high winds
Hi everyone we have had a bit of an issue with our yurt and were advised to try this forum for help but my other half had a lot of issues with trying to post on the forum so i'm having a go
My partner wrote this & then could not post due to getting a "We have marked much of your activity as suspicious, you cannot perform this function at this time" error from him trying to upload pictures. Could he please be unblocked (Username Marrv)?
Firstly let me say hello to everyone here, only just been directed to the site from another.
We put up our yurt in September in North Yorkshire, UK and have since twice experienced the same issue with it.
Before Christmas we had some high winds (gusts up to 50mph) which managed to push the windward facing side of the yurt wall inwards by 1-2 ft.
The opposite wall held in place (we braced the bottom of the lattice when putting it up) and the result was the door was leaning at around ~20 degrees (I thought was more).
Once the weather calmed we put the yurt back to how it should be (removed covers, re-positioned walls, re-centred the crown)
I then screwed internal blocks against the bottom of the lattice work, thinking that the reason the wall moved was the winds caused the wall to slide across the platform it is on (OSB boards).
At this point we also switched out to using ratchets on our bands as we had trouble getting / keeping them tight enough, we are fully aware that is is not ideal as it can easily allow for the bands to be over-tightened but are being as careful as possible to not do this.
Recently (last 2-3 days) we have been having high winds again & the door has left vertical again, but only by a few degrees this time. It seems as if the walls have shifted, and the roof poles are very tight on the door side & pretty loose on the windward facing side making me think the roof "half" has pushed over. The crown wheel supports where also no longer vertical either.
The sitting of the yurt is not in the open, it is shielded from the South side via a beech edge running east > west, the west side is pretty exposed though. The is an leylandii in the hedgerow fairly close to the yurt, the tree itself is stable & we know of the dangers of branches. The tree is likely to be removed this summer.
The yurt itself is also below the ground by one or two feet on the South side, and the west > east is on a slight hill (it is no-where near the top). Looking from the west to the eat;
We are currently looking at putting up a staggered wind break on the western side to break up this wind (in picture above will be in front of the yurt)
Anyone ever experienced this issue or have any suggestions, have contacted the seller & they "thought it would have been impossible".
As we are both (my partner & I) new to yurts we are somewhat flummoxed and inexperienced.
Tried to link or upload images but got a "please do not use remote images, upload them instead" error. As it will not let me link to where they are uploaded nor embed the image in the post not sure how to put pictures up!
happy...camper is offline   Reply With Quote
