Go Back   > Tags
Yurt Center Ring
The center ring is the part of the yurt that accepts the top end of the rafters. It is also known as a compression ring as the weight and load of the rafters is partially transferred to the ring. In many designs, there are pins on the end of the rafters that slide into holes pre-drilled into the ring. Other designs attach in different ways including bracketing. Colorado Yurts uses a method they call CORR:
Whereas Pacific Yurts relies on steel pins inserted directly into the ring:
The center ring is probably the most consistent feature throughout all yurt designs. It is the critical element in the architecture that keeps the entire structure erect.
Some designs, especially in areas with high snow load, will brace the center ring with posts or even a center pole.
What is the yurt center ring
  Thread / Thread Starter Last Post Replies Views Forum
Dan R-M
02-02-2022 03:47 AM
by thebitmaster Go to last post
23 33,419 Yurt Repair
01-03-2022 12:51 PM
by Bob Rowlands Go to last post
28 56,212 Building a Yurt
08-31-2017 08:19 AM
by Jafo Go to last post
33 25,933 Building a Yurt
ljamies1
08-30-2015 02:06 PM
by bob golding Go to last post
4 16,417 Building a Yurt
Dan R-M
08-01-2012 07:34 PM
4 5,340 Building a Yurt
07-27-2012 03:52 PM
9 4,819 Building a Yurt
dan
07-22-2012 11:23 PM
by HawaiiYurts Go to last post
4 4,273 Building a Yurt
Dan R-M
07-20-2012 06:35 PM
6 8,478 Yurt Repair
07-20-2012 03:01 AM
6 6,073 Building a Yurt
07-08-2012 09:54 AM
48 24,367 Building a Yurt
