Solar Panel Power To The Yurt
Old 03-09-2013, 12:59 PM   #21
Default Re: Solar panel power to the yurt
Our system is nearly up and running, we've been doing it in stages for our 24' yurt.
Stage 1: Honda EU2000i generator, used this to run power tools to build, and once it was finished (extension cord into yurt)
Stage 2: 8 Centennial GC-2 6v 225ah golf cart batteries in series/parallel for 24v 450ah battery bank, 1000w pure sine inverter with automatic transfer switch, and 1000w power-factor corrected 24v charger, started running romex and installing outlets in the yurt at this point
Stage 2.5: Victron BMV-600S battery monitor, this thing is awesome. Shows realtime flow in/out of battery bank, state of charge, time-to-go, etc...
Stage 3: 3 250w AstroEnergy panels, Midnite Classic Lite 150 charge controller - Installing tomorrow.
I designed the system to provide 2kwh for 2 days, with a discharge to 50% and derating for lower temperatures - so far everything has been working as intended, pretty excited to get the panels mounted up so we can stop using the generator to charge though.
wjdzl is offline   Reply With Quote
Old 03-09-2013, 01:46 PM   #22
I just got back from snowshoeing up to my yurt. You can tell it is Spring. The panels are pumping out way more power than they were a couple months ago. I charged up some power tool batteries, lanterns, etc., while I was there and it didn't even touch the battery. Fully charged when I left. Beautiful day up here in the North Country!
Old 04-12-2013, 05:53 PM   #23
I finally brought a multi-meter up to the camp last weekend and checked how many amps the 2 sets of panels (6 panels) were sending in: between 5.5 and 6.5 amps. Not bad. I just bought another set, and probably my last, for $139 (see HF catalog). Will be hooking that up soon. That should bring it up to between 9-10 amps on a sunny day.
solar
