05-21-2012, 06:56 AM
#14
I stayed up at the yurt Saturday night and decided to try and give the solar system a run for its money. When I arrived the controller indicated the battery was full and that it had stopped charging; so it was full. I charged up all the power tools, the rechargeable radios, cell phone and whatever I could find to plug into it.
I had these two lamps I brought up a couple weeks before but just one of them set off the inverter fan so I brought up a couple other ones I had at the house that we didn't use. They were these little lamps we put behind some of our furniture with the intention of some mild back lighting. They each hold one 9 watt bulb, but we found the light too bright at home, but wow, they work perfect at camp. Even with both of them on, the inverter fan doesn't kick on, and they throw more light than the full size lamps do. They seemed to be drawing between 10-18 watts each off the inverter so probably an average of 1.5 amps each. That means I could run both of those lights for 18 hours before half my charge was gone in the battery (you shouldn't use more than half).
I have to say, I am really impressed with that little solar system. I am going to add one more battery for extra capacity, and a 2,000 watt inverter so I have the ability to run power tools and that will be it. Viva la-solar!
