Question About Solar Power!
Old 05-14-2015, 07:23 AM   #21
Default Re: question about solar power!
Originally Posted by hierony View Post
The short of it--get a good quality inverter from a reputable maker, not the cheap $20 knock-offs that won't meet their own specifications, if they even give you specifications. You'll also get better quality electricity (better for motors, better for electronics). Get an oscilloscope and look at the output of your inverters vs your house mains and you'll see what I mean.
My smaller inverter is a quality one, but not a pure sine inverter. I found that running the electric through a surge strip is fine enough for my computers, flat screen monitor and other equipment. I have never had a problem with "dirty" power. I have also never had an issue with charging batteries with it, as long as I run it through the power strip. I have no idea why it matters, but I am not the only one to report this. Pure sine inverters are pretty pricey and I have yet to see the need for one.
My larger inverter is a Harbor Freight special. It doesn't get used very often. When I run the shop vac or a saw or anything else that needs a lot of power I use it. It has worked perfect for that stuff, but I would not rely on it for constant use. It is a 2000 watt/4000 peak inverter.
My dad was in radio biz from the gitgo. He had a ham set up. dah-di dah-dit --dah- dah dit- dah. That was 55 years ago and I still remember CQ. lol
Same thing with my father and grandfather. There were nights when I was away and I could swear that I could still hear the Morse code in my head lol.
I just have a tech license, no code required. In fact, there is no code requirement for a general license anymore. I just haven't had the time to study for the test.
solar
