Go Back   Yurt Forum - A Yurt Community About Yurts > Member Yurts > Clean Air Yurts's Yurt
Dome?
Old 02-18-2013, 07:11 PM   #1
Default Dome?
Is there any kind of
or coverings that goes over the
center ring
to your yurts?
Old 02-18-2013, 07:19 PM   #2
My yurts do not use a
, but instead use a flat double wall Lexan skylight design. Because
Clean Air Yurts
are designed to be ultra portable and lightweight, a dome would take up too much space and bulk to pack efficiently. Ever tried to put a 3' dome inside of a standard car seat or in a trunk? Not to mention the weight of the domes.
Now domes are perfect for yurts that see heavy snow and are permanent, but our yurts are made to be light and easy to setup and transport, so the flat skylight design is the perfect fit.
Old 02-18-2013, 07:37 PM   #3
Do you have any pics of the double wall Lexan skylight? Sounds interesting.
Old 02-18-2013, 08:05 PM   #4
This shows the flat plate. It is mounted on brackets that allow it to be raised for ventilation but still have full coverage from rain, or mounted tight against the roof to seal in heat and seal out rain.
Old 02-18-2013, 08:06 PM   #5
I can take a picture of one in the shop if anyone is really interested.
Lucy Willemsen and Orions_End like this.
Old 02-18-2013, 08:46 PM   #6
Yeah man, you can't just leave us with that vague pic lol.. Need to see more on how that operates!! Looks pretty damn cool.
Lucy Willemsen likes this.
