Zippered Window Systems
Old 08-07-2019, 04:11 PM   #11
trihartsfield's Avatar
Default Re: Zippered window systems
Here is my thought: Attach a loop/ring behind the flap with glue or some sticky material. Have another attached to the outside above the window. Attach a piece of webbing material to the one behind the flap, run it down to the bottom of the flap then up to the second loop/ring so you can pull the flap up and then attach a third loop to the base of the
to tie it to.
You would need at least two of those per window.
Does that make sense?
Chris
