Mike, that might go well in the "Yurt Permitting" section I posted a while back. Keep in mind, every area is different and every area that isn't yurt friendly could use a persistent group of people to help educate officials as to the strengths and durability of yurts. Go with a good, reputable company that has done their engineering. That's critical for a yurt you hope to build 'permanent'. If you have that, you're halfway there. The other half is being diplomatic and persistent in getting that info out there to the right people. Get a local architect to help you.
The only places I wouldn't put a yurt and expect it to withstand the elements are in zones where hurricanes hit frequently and you have to worry about other people's homes coming and wiping out your yurt. But then, I wouldn't put many houses at all in that situation... maybe a monolithic
It's all about shifting these modern paradigms of ours. Officials can be the hardest to bring around, but it can be done. Just point to areas where it is being done already and make their job easy.
Regarding the article, what a great review/recap for Pacific Yurts. It's always great to read successful yurt stories, isn't it?
