Hunter Stove Upgrade
Old 11-11-2015, 07:35 AM   #1
Default hunter stove upgrade
Hello everyone!
I want to use the portable hunter stove for my yurt. I purchased it second used. It looks not very good. There are many scratches. What can I do with it?
Can you suggest any advice on how to paint it.
thanks
rickchap is offline   Reply With Quote
Old 11-11-2015, 11:02 AM   #2
Default Re: hunter stove upgrade
If you are refering to the 'hunter' cylinder wood stove, that is a very well made stove. Use black stove paint to renew the looks. Fire the stove outdoors or outside the tent to cure the paint.
Old 11-12-2015, 02:52 AM   #3
Thanks, It is a good advice
I my local store I was advised to take this can https://www.mrosupply.com/paint-pain...k01618_krylon/
I have some questions about the painting process. How to prepare the surface? I mean, can apply it without degreasing? Should I spray one or two coats?
Old 11-16-2015, 01:08 PM   #4
I've never used stove black/ Common sense approach is make sure the paint goes onto a grease free surface that has no flaking rust. Wire brush sand degrease etc. I'd guess two coats would give the best coverage. Fire the stove outdoors. All just a guess never done it. Good luck.
