12-25-2024, 05:35 PM
#1
Re: Anyone purchase a Smiling Woods Yurt?
Merry Christmas Yurt People!!!
Sure, my yurt is 36' in diameter Smiling Woods Yurt. The walls are 10' high. From the floor to the base of the compression ring is somewhere around 18'.
The whole skylight was a big ordeal where it eventually started leaking. And my solution to the problem was to remove the skylight and replace it with a cupola. Which, has normal vertical windows that open/close for ventilation. But in order to open and close them, I wanted to be able to have easy access to the cupola. So, I had a welding friend manufacture that platform. The platform itself is roughly 4' in diameter and hangs about 32" down from the base of the compression ring (Just enough room for you to climb up there with a ladder from the loft and stand up without knocking your head on the cupola).
That's it in a nutshell! Leaky skylight solution!
Will try to post some more pics!
