Old 11-08-2019, 01:35 AM   #1
That sounds in the ballpark. Sounds like the labor cost to construct is pretty low, but good for you if that's the case! A typical equation for labor is to double the material cost, so you pay 65k for the kit, foundation, and interior wall materials, estimate another 65k for construction of the kit, foundation, and interior walls. Some places are even higher for labor. Other things to consider: Gutters? They didn't have an option when we were looking. Our clients added a covered deck and theirs was two story. We also have codes that required stem walls for the foundation.
I'll say again, I like
Smiling Woods Yurts
. They're a great value for what you get. But I think some people see that $60,000 pricetag and have no idea that there's another $60k to go to implement it. (In our client's case the kit didn't include about $60k in additional materials including the deck materials, foundation, ceiling, gutters, interior walls, so their true material cost was I think closer to $120k - It's been a while since I looked at the details though).
Thanks for sharing your real time experience, amaralice! That's what it's all about - all of us sharing real knowledge and experience to help others <3
Old 11-08-2019, 10:02 AM   #2
Melissa, thanks for bringing 'building costs' into the light. Hopefully that will help folks looking to build a yurt.
Old 06-17-2020, 06:47 AM   #3
Looks good. That's a big yurt and a beautiful location!
Old 06-21-2020, 07:39 AM   #4
Nicely done.
Old 04-14-2021, 12:08 PM   #5
Hi Everyone
I purchased a Smiling Woods Yurt and wanted to share my experience. Because when I was doing research, there wasn't a lot of information available at the time about the company. So, overall their product is high quality. What you get delivered is basically the structure/the shell. And everything inside you or your contractor have to build. In my package, I decided to go with a pop out room which was included in the initial design. The company informed me that Smiling Woods would send the roof material for the pop out room and the cedar siding, but my contractor would have to build the room itself. Once we received the tractor trailer, we realized that "the roof material" meant that they sent the metal roofing (no rafters included). Also, they didn't send enough cedar siding for the pop out room and we had to find some on the East Coast which was not easy to do and was expensive.
In my package, I went with the more affordable option of the birch plywood ceiling panels. My yurt is in the Northeast of the country, which is very rainy. The assembly of the yurt actually happened in the snow and rain. In order to cover the structure, the metal roofing needed to be attached first. And consequently, the
and ceiling panels installed later. There's no way in this climate that you can install the panels and
first. So, the way we had to do it was very hard. Basically the metal roofing was installed, then spray foamed inside with insulation. Then, with scaffolding, slide each panel up through the rafters and basically toenail the panel in with a brad nailer. Very hard. Lots of the panels are warped and also had to be trimmed or actually some had to be made bigger. It was a seriously hard thing to do. After installation, sometimes the panels pop out and I have to climb up there and try to pull it back in. I don't know if the tongue and groove would actually be any easier, but you probably wouldn't have the popping out and warping problem.
Also to note that there is no way fiberglass batting insulation would work here. I wouldn't use anything other than sprayfoam to make sure you have a seal to avoid any condensation and add strength to the roof...which was of a significant cost.
My particular design was more difficult because I had an existing concrete pad. So, the company told me the designer that they normally use in house probably wasn't the best to handle my design due to the unusual engineering of the pad. So, we had to use an outsider designer that they recommended who was very good...but came with an extra couple thousand dollar cost.
I called the company and emailed A LOT during my assembly. And they answered the phone every time and tried to answer all my questions. I never had a problem with communication. Having said that, the salesman sometimes would say things things that didn't seem to quite pan out. But, every issue I raised they did address eventually.
Some things I had assumed would be included in the package. For example, fascia for the outside trim. And if you want to match the cedar included in the package, it's hard and expensive to do that if you live on the East Coast. But no extra trim was included. As said above, of course, insulation is a huge extra cost that I hadn't considered and wasn't included.
Overall I love my yurt and anyone who visits is very impressed. It's absolutely good quality. I feel like the company presents the package as a do it yourself yurt. While I am no contractor, I built out the inside rooms and loft myself. There is NO WAY I could assemble this yurt by myself. You need a professional contractor with lifts and heavy duty equipment to place the compression ring and roofing on. Also, the yurt is tied together with heavy duty metal cables. There is no way I would trust a layperson to handle that. So I recommend using a professional.
The things that are included like the windows and the doors were very good quality. The doors are beautiful and solid, had to finish them with varnish, just like the ceiling panels were unfinished too.
After one winter so far with the yurt being heated, I did have some condensation issues from the skylight. I would say when it's really cold, single digit temperatures, condensation pools around the bottom of the skylight and drips down onto the floor. It's not a lot. It's a few drips. I addressed it with the company and they recommended some caulking which I have yet to do because I had to order an 18 ft step ladder to get up there. I have a feeling the caulking isn't going to work. But I will try it. I tried circulating air on it, but that did nothing. I think I will have to somehow prevent warm air from reaching the skylight in the winter. But would love to hear if anyone else has addressed this issue with a wooden yurt as opposed to canvas.
If anyone has any questions about Smiling Woods or my yurt construction, please feel free to ask. Overall it's been an amazing adventure and experience and very grateful for my beautiful home.
Jafo, TSRalex and equinegirl like this.
Old 04-14-2021, 05:02 PM   #6
What a nice, thorough, honest, and helpful review! Salute!
Old 04-14-2021, 07:54 PM   #7
Yurt Gurl.
Great info. I posted about my Smiley Yurt in the message above yours, and would say your experiences were similar to mine. I had a neighbor who had a nice crane that we used to hold the ring up at the top, and hired an engineer to review the installation of the
tension cable
We went for the pine tongue and groove ceiling and are in Arizona. We had shrinkage so there are alot of gaps between the panels. That is my biggest complaint. It would have been better to set the panels somewhere to acclimate before installing, but this is new construction so there was no place to do so. We also spray faom insulated everything which while costly, really does work nicely.
Sounds like similar experiences - and I think if you are willing to do the work, smiley is a good option.
1daveman is offline   Reply With Quote
Old 04-15-2021, 08:17 AM   #8
Thanks HawaiiYurts and 1daveman! And yes, I agree. It's so much work, but worth it in the end
Yeah, I think they could come up with a better ceiling option, I'm just not sure what it would be. I had the panels inside for a while and also polyed them all before install and they are still popping and warping.
Just curious...have you had any condensation issues from the skylight? I know Arizona is a dry climate...But just curious?
Old 04-15-2021, 09:46 PM   #9
No - we dont have any condensation, but AZ has been quite dry so who knows!
Old 12-14-2021, 12:15 PM   #10
I just wanted to post a follow-up for anyone out there having problems with condensation in a Smiling Woods yurt around the frame of the skylight. I tried a couple different things. Fan does nothing. Window plastic just created more of a humid wet zone in there. So I thought about stuffing fiberglass insulation around the ring. So far, it seems to have worked. But, it's only December and hasn't gotten extremely cold yet. But, I purchased an 18 ft step ladder (insanely expensive) and shoved a bunch of insulation up around the skylight frame. I can't open the window at the moment. But that's fine, because it's winter. Aside from that, no other problem. And in the spring, I'll just remove the insulation. I will try to add pictures if this helps anyone.
smiling woods yurts
