Yurt Owner Wannabe
Old 02-02-2014, 04:29 PM   #1
Default Re: Yurt owner wannabe
With a concrete pad you might also consider raident heat in the slab.
dlhall likes this.
Old 02-02-2014, 08:03 PM   #2
Default Re: Cement pad
Thanks for responding. . The plan is radiant infloor heat using glycol warmed by heat exchanger tied to propane hot water tank. Low-tech, little power consumed to circulate. The goal is a warmish yurt augmented by a wood burning cooker to bring it up to a warmer room temp when home. This will be in central Alberta & with our winters that can be brutal I'm thinking both heat sources might be required in worst part of our prairie winters.
Old 02-02-2014, 08:05 PM   #3
Default Re: Yurt owner wannabe/plumbing
Wise words on thinking of plumbing. We're working on that too.
yurtz by design
