Yurt On The Ground
Old 09-01-2015, 09:14 AM   #10
Default Re: Yurt on the Ground
Thanks Bob! I did some research on insulating earthen floors and the info that I've found makes it seem climate dependent on whether you should insulate or not. In hot climates, un-insulated ground contact will serve to help keep things cool, whereas in cold climates the result is the same but with more important consequences during winter. Where I'm at it is hot and humid during a good portion of the year, and winters aren't too bad. Will require more thinking and research on my part. Back to work for me too!
tboulden is offline   Reply With Quote
pacific yurts
