03-10-2020, 08:43 PM
#8
Re: Wood Stove Rear Flue Exit?
Hello , first off heat is omni diertional, but not straight up, it will always go to the cold and most likely you have already proven that, when you sit at the campfire you feel the heat even tho you do not sit right ontop of it the ground under the fire is warm as well, now that out of the way the out the back was created because some people think stove pipe are ugly to look at , and you have more cook surface on top with the vent in back but you can take it straight out the yurt wall to your T, or if you want more heat bring it up above the stove, and then out the wall, it will not matter, just what ever you like but if you bring it up then you can get one of those fan for the pipe to push more warm air in the ger/yurt, but remeber its your yurt and what ever you decide is the correct way,
enjoy your ger/yurt
