What Maximum Diameter For Skylight / Tono?
Old 07-23-2018, 07:46 PM   #1
Default What maximum diameter for skylight / tono?
How big can I make my skylight hole / tono?
I reckon I could go as wide as 6ft (about 2 meters), if not more. 3m would make it look stupid maybe.
I guess the only thing that limits the diameter of the skylight hole would be the rigidity of the tono ring? Just build it stiff enough so it doesn't flex or warp under load.
Laminated ply and epoxy is my planned building material for the ring... more simple than the timber and ply sandwich I did for my home-yurt.
I'm thinking of starting my third yurt build, to go alongside the one I live in. I built a 16 ft, a 20 ft, and now I'm planning a 25 to 30 ft for a workshop/boat-building space.
There needs to be a lot of light inside, so as well as the big tono skylight I plan to roof it with some clear cover panels to let the light in.
Cheers in advance for the suggestions regarding the maximum size of the tono.
