Traditional Yurt: Felt Inside Or Outside Drip Edge?
Old 05-09-2023, 06:10 PM   #11
Default Re: Traditional Yurt: felt inside or outside drip edge?
Yup, rough. Tough too. Like my wife says when I pull her close for a goodbye hug in the morning. She grabs my arms and says, "Don't ever lose those 'guns, Bob.". haha
Good luck. Have fun.
hahaha
thanks, rasising day is tomorrow (amm located in portugal)
one last one:
to tie the rope to the rings on the door/window......what knot would you use?
calcetines is offline   Reply With Quote
Old 05-09-2023, 07:51 PM   #12
Well isn't that somethin'. My wife is Portuguese. It just dawned on me, it should be dawning on you shortly. haha Get some rest. You're gonna need it.
Old 05-15-2023, 02:54 AM   #13
So we made it! 24 ft yurt, three healthy men and we stopped when the first water protecting layer was on.
On the following morning we placed a UV protecting layer and the outside canopy. Now moving on to finishing jobs & bed building, my third son is due to be born begin july.
Now I know from experience how rapid yurts can be raised, this was our first time and we countered a couple of manufacturing mistakes so normally with 3 people you can get it done easily within 8-10 hours.
Name:	WhatsApp Image 2023-05-12 at 18.39.37.jpeg
ID:	1505   Click image for larger version
Name:	WhatsApp Image 2023-05-12 at 18.39.36.jpeg
ID:	1506   Click image for larger version
Name:	WhatsApp Image 2023-05-14 at 08.43.21.jpeg
ID:	1507   Click image for larger version
Name:	WhatsApp Image 2023-05-14 at 08.44.30.jpeg
Jafo and TSRalex like this.
Old 05-15-2023, 02:58 AM   #14
This picture is not our Yurt, but here you can see the last two layers before the outside canopy.........can anyone tell me more about the qualities of these layers? Especially the black one?
I tried a google search, it's used in roofing I guess, the name is "Esterre 60 - HPV".......the seller brands it as breathable, non-permeable cover.......do you guys have something similiar?
The white one is sold as UV protecting, I guess to protect the mentioned black cover
Name:	6.   regendak II.jpg
Old 05-15-2023, 07:28 AM   #15
Making good progress. Get some stairs built and walk right in. Beats me what that '60' stuff is.
Old 05-17-2023, 04:01 AM   #16
Question Re: Traditional Yurt: felt inside or outside drip edge?
UV protecting layer
outside canopy.
I´m a little bit confused on your layer system - can you explain it more detailed and describe the used material of each layer?
Old 05-17-2023, 04:14 PM   #17
Yeah sure. Ok so I bought the yurt from a spanish company so I have to translate some words:
First layer Cotton inner fabric
Second layer 3cm felt
Third layer Esterre 60 - HPV (the black stuff). On the order it's called "membrana extra impermeable y transpirable" which translates as "extra waterproof and breathable membrane."
Fourth layer A plasticy looking white fabric which is called "membrana impermeable anti-uva" on the invoice, I thought uva was either a typo or meant as much as anti UV
Fifth layer is a thick outside canopy
Wondering if the 3rd & 4rd layer is commonly used......What is a actually a common layer structure? Inner fabric, felt and outer canopy and more???
[COLOR=rgb(100.000000%, 0.000000%, 0.000000%)]
[/COLOR]
Old 05-18-2023, 09:06 AM   #18
Mongolian trad yurts the layers are white liner, then felt, then cover. The first layer keeps the interior bright, and probably clean. My guess is felt picks up all manner of litter when off the yurtwhile being moved. Just a guess.
Old 05-19-2023, 12:31 AM   #19
First layer: Cotton inner fabric
OK - the decoration layer....
Second layer: 3cm felt
OK - the
layer....
Third layer: sterre 60 - HPV (the black stuff). On the order it's called "membrana extra impermeable y transpirable" which translates as "extra waterproof and breathable membrane."
Mmmmh - why is an "extra waterproof" layer needed, below other (4th & 5th....) layers?
Fourth layer: A plasticy looking white fabric which is called "membrana impermeable anti-uva" on the invoice, I thought uva was either a typo or meant as much as anti UV
Mmmmh - why is an "anti UV" layer needed, below an other (5th) layer?
OK
Exactly that was/is confusing me on your layer regime.....
"Common" is depending on location and time (summer/winter) of usage.
Insulation
can help to keep the Yurt warm, but with the right material (e.g. aluminum reflectors....) you can keep the summer heat outside too.
Yes - change "felt" to "insulation" and I can agree....
Old 05-22-2023, 04:00 PM   #20
allright, thanks for the replies. I'll go find out some more about that esterre HPV stuff
