08-29-2012, 04:29 PM
#5
Originally Posted by Pacific Yurts
Hi Jafo,
The rafter support in question can be removed, but I would use it to frame across horizontally between the neighboring rafter supports. (Higher on the wall is better than low because it will help the yurt to resist torque.) However, you do not need to remove the rafter support. You can simply move your stove pipe over the left a little so that you maintain a 2" clearance from the pipe to the rafter support. The stove flashing will not be centered in the "diamond" area of the lattice wall, but will function exactly the same.
Ok, great, thanks! Hopefully will be getting this done in a couple weeks. Starting to get cold here!
