Stove Is In
Old 08-28-2016, 08:47 PM   #1
Stea's Avatar
Default Stove is in
Installed the wood/coal stove this weekend.
Followed Jafo's install , worked out perfect . THANKS JAFO. I welded up a heavy support post and base. Base was staked with 24" steel spikes. It's solid.
spent our first night in the yurt last night. Time to sell the travel trailer.
Jafo and hierony like this.
Old 08-29-2016, 07:28 AM   #2
Default Re: Stove is in
Looks great and I like the additional stakes. Looks like you left yourself the ability to go higher which is good. I found that mast worked out great for attaching an antenna to.
Old 08-29-2016, 08:30 AM   #3
Stea's Avatar
I've still got a 2' section of chimney I didn't use.
I think I will add to the support pipe and use the 2' pipe this weekend .
Old 08-29-2016, 09:00 AM   #4
The more pipe you have, the better your draft. Good idea.
Old 09-06-2016, 02:56 PM   #5
Stea's Avatar
Added the 2' section of pipe, better draft now.
Still trying to figure out how to get a coal fire started and to keep it going.
Im going to try the charcoal method this weekend.
