Slabs And Radiant Heat
Old 04-28-2022, 07:41 AM   #11
Default Re: Slabs and radiant heat
If you go to houseneeds.com you can find the Myson CV21 series. 8" tall and 32" long. 2000 BTU each for $100. You just daisy chain them together around the wall until you get the BTU output you need.
Old 04-30-2022, 06:43 PM   #12
trihartsfield's Avatar
ToddL,
Couple of questions: What region do you live in, ie; what kind of weather do you experience?
Are you off grid?
Are you planning on living in the yurt full time?
Are you going to have a bathroom and kitchen in the Yurt?
Old 05-01-2022, 08:13 AM   #13
'Homeless depot' haha I tell my wife I'm headed to homeboy. I call their competitor something I can't say here. Good job on the radiant heat Krusty. Thanks for the info.
Old 05-06-2022, 10:08 AM   #14
I can help you through some of the calcs if you decide to go radiant. But if so I'll need to know things like:
- what power sources are available to you and what do you prefer to use?
- are you trying to do electric or circulated hot fluid?
- how cold will it get outside and how warm do you want to be inside?
- is your yurt going to be insulated? with what?
Regardless if you're doing a slab, you'll want to insulate under the slab really well. If your 30' yurt has 7'-ish walls and an eco-foil like
, you'll want at least R22 worth of foam board below your slab to keep heat loss to the ground to less than 5%
