Pros & Cons For High/low Walls (lattice)?
Old 10-14-2020, 06:09 AM   #1
Default Pros & cons for high/low walls (lattice)?
Just want to read about the heights of your Yurt-walls and to collect the pros & cons for high/low walls (lattice) and ask you all to share your experiences.
For me are the pros of a high wall (e.g. 250 cm) in the possibilities to build in an bathroom and to use the ceiling as additional bed.
And the whole room has an generous effect - in Yurts with low walls I feel more constriction.
An additional point is, that I believe
has not so much chances in bigger volumes, or is that an false conclusion?
But an Yurt with low walls is easier to heat.
Blaidd-Drwg likes this.
