03-11-2014, 11:55 PM
#2
Re: Portable platform questions.
I'd forget T&G on a semi permanent yurt floor. The stuff needs pried together with a flat bar. Sometimes pried in a BIG way, as in wail on it. lol If you lay the flooring on a right angle to the sleepers it would be pryable, but it isn't worth the big expense IMO.
If you opt for 2x lumber atop 2x10 sleepers on the ground, use pressure treated lumber for the sleepers. I'd also lay out plastic sheeting down before you lay out the 2x10 sleepers. Water may get on the sleepers, but at least they won't be contacting the ground.
Another option would be 4x4 pressure treated sleepers on 2' centers. They are rated for ground contact. I'd still place them atop sheeting myself.
Another way. Lay your 2x10s atop shipping pallets. You might be able to get them free if you scrounge around. They'll certainly be less than any pressure treated sleepers.
Either way, layout plastic sheeting. Earth contact is bad regardless of what they say. Also, lay additional plastic sheeting atop the pallets before laying out the 2x10s. Sheeting will stop the breeze and the bugs from coming up between the cracks in the 2x. Butt the 2x10s tight to eachother, as they will shrink as they dry out. Your full length 2x10s screwed into each pallet will self level the pallets.
