01-04-2015, 12:46 PM
#230
Re: Planning to build a yurt in Czech Republic
If there's a warranty, use it. If it really is just too much to hassle with, use Aquaseal. If you are concerened about stitching leaks, you can Aquaseal the entire seam. I've Aquasealed every seam of our tents rainfly, and the tent floor. ZERO leaks.
FWIW, I also use the stuff on neoprene and breathable waders. Totally bombproof repair. Also touched up seam leaks on poncho hood. Really, the stuff is incredible. I've also built up the toe of my work boots with Aquaseal so the sealant wears off instead of the leather. It is urethane, and urethane my friend is some VERY tough stuff. God luck.
