Insulation In The Pacific Northwest
Old 08-19-2015, 11:44 AM   #2
Default Re: Insulation in the Pacific Northwest
Hi Janine,
Our insulation will not hinder ventilation for the yurt. It is installed between the wood frame of the yurt and the exterior covers.
If you plan to live in the yurt full time I would highly recommend that you insulate both the roof and walls for the Pacific Northwest region. However, if you plan to use the yurt recreationally you might be fine without the sidewall insulation. If you do install the yurt with only partial insulation, omitting the wall insulation would be the way to go since it is easier to add later when finances allow for it.
mama23 likes this.
insulation, pacific yurts
