Infloor Radiant Wood Fired Slab?
Old 07-17-2014, 04:49 PM   #1
Default Infloor radiant wood fired slab?
First Off, I am new to this forum having just discovered it. What a wealth of info for the first time yurt erector ! My wife & I are soon to put up our new 30' Pacific yurt on our parcel here in southern Oregon. The driveway has been developed to the homesite and the well is hooked up. My choice of site is based on a need for summer shade balanced with fire safety and being able to work with the grade of the slope. My next task is to-
A) Build a deck platform-Pier blocks,pressure treated lumber, SIP floor & outside TREX decking and heat with interior woodstove(less time,work & $ ?)
OR
B) Pour a reinforced slab with pex for an outside wood fired boiler & hot water radiant floor heat(more time,work & $ ?)
Either option is not cheap- Even if I build the deck with a friend who is a master carpenter( I also know my way around tools and construction)AND has all the tools AND has built 4 different yurt decks, It will be around $6-8000. I already have a stove. My concrete pouring friend says he can make me a 30' reinforced slab with pex for heat and chases for water, sewer, propane & eletricity for probably much less. I would have to sell my stove and get a more expensive boiler. Who does not like the idea of a warm floor in the cold wet Oregon winter, never bringing wood into the house & the interior space freed up by the stove being outside, no smoke or ashes inside ever. BUT- will it keep the space warm enough? Will the cover and walls radiate heat out faster than the slab can warm the interior space when it is 30 or 40 degrees outside for four months straight? I like it warm in my home during the winter months as I work and play outdoors. I love my Vermont Castings Encore stove a lot. Any one have any experience or ideas regarding this scenario? I like to keep things fairly simple and I think that even though the deck option will be more work for me, the woodstove inside is likely to be warmer. The cost of the wood fired exterior boiler will make the slab option more expensive , though I am not against spending the $-If it is a better way to go. Wood is not a problem as I have a sixteen acre woodlot. I bet both options use the same amount of cordwood, so I don't see that as being an issue. Thanks for any insight to my query, Enzo
Enzocann is offline   Reply With Quote
pacific yurts
