If you have pitched your roof at 30 degrees and the diameter of the rafter break is truly at 24' diameter,
can build you a replacement 19 oz. vinyl roof - your choice of fifteen colors with a ten year pro-rated warranty. I would recommend a
roof with a fifteen year warranty. If you select a standard color we could have it out to your next week. Unusual colors (pink, yellow, purple, etc.) will add a week or so to the turn-around.
Did you make your walls out of canvas also? Should replace at the same time.
We accept Visa, Mastercard, Discovery, and Amex.
jer
P.S. I didn't read the whole message thread, but if you live somewhere with more extreme conditions (Hawaii, high desert, etc.) we will only ship you a
roof. Good Luck.
