H2o
Old 03-20-2016, 08:59 PM   #1
Default H2o
Putting a yurt on a deck. Anyone got any grand ideas for insulting water from where it comes out of the ground until it goes through the floor. Our deck will be a ft or 2 off the ground. Pics would help. Thanks
newt is offline   Reply With Quote
Old 03-20-2016, 10:21 PM   #2
Default Re: H2o
Build a 2x chase around the exposed pipe. Thoroughly insulate the inside of the box. Screw on one of the side panels so you can gain access. This works very well until extreme bitter cold below zerowhere electrical heat tape wrapped around the pipe itself will be necessary to prevent freezing.
Old 03-20-2016, 10:22 PM   #3
Default Re: H2o
Oh, and also wrap foam pipe wrap around the supply and seal with tape. That is a good plan in the floor framing as well.
Old 03-22-2016, 06:40 AM   #4
Default Re: H2o
I would do what Bob says, but do wrap the pipe in electric
tape. It doesn't mean you always have to have it turned on, but better to have it on those really cold days.
