Flooring Options
Old 06-23-2017, 08:48 AM   #8
Default Re: Flooring Options
Now I'm even more confused. If you erect a yurt without first installing the subfloor, what are you putting it on? The ground?
To be clear, I should be okay with putting the yurt directly on the 3/4" plywood platform, and installing the finish floor (either hardwood or engineered flooring) later, correct?
Old Man Oldman is offline   Reply With Quote
