Dude It's Cold! Installing A Wood Stove
Old 10-24-2023, 05:40 AM   #1
Default Dude it's cold! Installing a wood stove
Ok here we go. I've bought a 2nd hand iron cast wood stove. I read a couple of threads about chimney support here and this is my plan and my questions.
We live & build on a budget. I want it safe and reliable. And foremost prevent problems regarding draft rather than having to find a solution with smoke in the yurt on a cold day.
I plan to place the stove 35cm (14'') from the wall. Is that enough distance ro prevent the inner fabric from
up too much? The stove has a back, horizontal exit
From the stove runs a double walled 80cm (32'') pipe trough the 'wall exit'. 1 meter long, about 3 ft. This gives me on the outside of the yurt a spacing of about 2 feet between yurt outer wall and chimney.
To go from horizontal to vertical I can use a simple 90 degrees corner piece or a 'cleanout tee'. What would you advice, is the cleanout option a must have or is simple turn also fine?
Any advice against a 90 and rather use 2 45's? I reckon this is not an issue since I have only one turn in my setup
I am thinking to start off with two meters of vertical pipe. Should this be double walled as well to prevent creosote piling? What's the downside of using simple inox pipe?
Lastly I guess I need to place something under the stove to prevent the floor from getting burnt. I would like to use tiles. What tiles can I use? Ceramic or do you need something special heat proof? Maybe a cheap solution like pizza oven stone?
calcetines is offline   Reply With Quote
