Design Yurt After-build First
Old 01-13-2014, 07:36 PM   #4
Default Re: design after-build first
You can build the circular platform before deciding on window and door placement, but you will need to decide where the initial door will be located before assembling the yurt onto the platform. If you will be ordering fabric windows that are integrated into your side cover you will need to decide on the placement of those windows relative to the door location before you order the yurt. However, our glass window system can be installed wherever you wish, so you do not have to pre-determine where they will be placed.
If you decide to retrofit additional doors at a later date that can be done, but it is best to avoid installing them where existing fabric windows are located.
I hope this helps!
pacific yurts
