Building A Yurt With Two Doors
Old 08-20-2014, 04:19 PM   #1
Default building a yurt with two doors
what special considerations would i need to attend to when building a yurt from scratch with two doors? first of all, is it possible? i'm considering building a canvas yurt with a front door and a door opposite it to connect to a second, smaller yurt.
lemon_verbena is offline   Reply With Quote
Old 08-20-2014, 06:12 PM   #2
Default Re: building a yurt with two doors
Not only can todays modern yurts handle two doors, they can handle three or even four. How? The
tension cable
wrapping the yurts circumference effectively transfers the roof load to the wall lattice. I deliberately ran my
tension cable
entirely around my yurt, including OVER the door frame, so there would be no surprises in the worst wind. Modern rope wire tension cables have incredible reserve of strength.
As long as there is a strong knot free header in the door frame, and a strong cable, two doors is no problem at all. Keep them spaced a ways, like on opposite sides as mentioned, and go for it.
Old 08-20-2014, 11:23 PM   #3
again, very helpful. thank you!
Old 08-20-2014, 11:27 PM   #4
You're welcome. Best wishes to you and yours.
