08-31-2014, 10:07 PM
#5
Re: Building a Yurt
Yes, on a 12' diameter yurt bind is normal, especially on khana lattice that isn't steam bent.
Why? Take a look at one of the lattice strips once erected. See how much it twists from top to bottom? If you have your khana postioned so the lattice crosses form squares, not diamonds, you have the maximum twist. Not only does it twist, but the knoted cord at the crosses makes the lattice bind against eachother. The little bit of slop in each knotted cord joint is taken up by the twisting force. In a bolted frame, like mine, there is no give and the bind is even worse.
Don't worry. In time the khana will loosen up somewhat as it takes on the installed shapet.
I like your 9 cross khana. Good job.
