30ft Workshop Yurt Build (9 Meters)
Old 09-03-2018, 02:49 AM   #1
Wink 30ft workshop yurt build (9 meters)
I'm building a 30ft (9.15m) yurt for use as a workshop. This will be the third yurt I've built, and I'm kind of just winging it on this one, no plans... just taking what worked on the previous yurts, and using general tried and trusted yurt design elements.
I'll post photos as I go.
Today the timber got delivered! It's Pinus Radiata, a relatively soft pine species widely used for framing buildings here in New Zealand.
This time I'm using 1"x4" (20mm by 100mm) for both the khana lattice and the roof rafters. It may be a strange design choice but the timber was cheap at NZ$1.25/linear meter. I think it'll work!
Plus it's CCA treated H3.2 wood, so it will last for decades and decades.
Please feel free to offer criticism, or advice, or ask questions as I build and post my progress here.
Don't expect quick progress however! I'm also studying full-time so this is a weekend project.
Old 09-03-2018, 07:29 AM   #2
Default Re: 30ft workshop yurt build (9 meters)
I can't remember what your snow is like there, if any at all, but tell me, will there be any supporting columns (other than wall studs)?
Old 09-03-2018, 08:08 AM   #3
Definitely looking forward to the build. Thanks hobbit.
Old 09-15-2018, 05:04 PM   #4
Here's the bending form, to bend the steam-heated 2x4 wood, to form part of the 2.5m skylight ring (8ft).
The ring will be made of 4 rings of 2x4, laminated and screwed, to finally make a finished ring 4" thick, and 8" wide.
Maybe I'll need to add an extra 5th ring if it's not stiff enough, but I'll come to that later.
I've used two different methods to build my previous two yurt skylights, and this steam bending +laminating is new to me, and will be fun.
Old 09-15-2018, 05:12 PM   #5
You know you're building a big yurt, when you have to look up Vehicle Load Maximum Dimensions, and size the parts to be just smaller than that. Maximum sideways load for a regular car in NZ is 2.5m.
Old 09-21-2018, 05:24 PM   #6
Skylight ring / Tono steaming day!
This basic setup is what I'm experimenting with...
Steel pipe.
Boiler made of old gas bottle cut up.
Rags.
Gas cooker.
Steam for maybe 3 hours, then bend to the form. The timber is already clamped to the bending strap as it is steaming inside the pipe.
Old 09-21-2018, 06:08 PM   #7
Fail!
Not enough steam was generated by my gas cooker. Half the pipe got to maybe 70degC, but the far end was cool to touch even after an hour. The whole thing needs to be full of boiling steam.
I'll get a more powerful gas burner and try again another day.
Old 09-21-2018, 06:52 PM   #8
Can you put a burner on both ends?
Old 09-21-2018, 06:58 PM   #9
Hmm... good idea, thanks. Next weekend I will try again.
Old 09-22-2018, 07:20 AM   #10
I got a couple comments. Steam is nothing to mess with. Steam needs to escape the pipe. You definitely >don't< want the pipe pressurizing in a Rube Goldberg homebuilt steam bending setup. Typically only one end of the pipe has steam enter and the other end steam escapes or an explosion can ensue. But that's coming from a guy who's never successfully bent wood so take it for what it's worth. Whatever you do-be careful.
