06-06-2016, 08:22 AM
#9
Re: 30 ft yurt from scratch
Got some time this weekend to process almost all of the remaining Khana pieces. In addition I also began laying out the compression ring. Shown in the picture is one layer of what will be a three layer compression ring (with through bolts holding the layers together as well as wood glue in between). The ring is made from 12 2x8 cut with a 15 degree angle on each side. With all three rings sandwiched and offset so the seams don't all line up it will be 4 1/2" tall and 5'3" across. The outside gets trimmed to a circle and then it's all sanded and sealed with a lacquer.
I originally planned on drilling holes where the 2x8s meet and then using wood glue and dowel rods to hold them together, but I am looking for input from more experience carpenters on whether that is necessary. Each 2x8 will have a bolt on each side, and the middle 2x8 ring (which is sandwiched between the other two) will be offset so it bridges the seams. Do you think the through bolts alone will be enough? (Either way I plan on using wood glue to hold everything together until the three rings are made and I can bolt them together)
