Yurt Design Software?
Old 04-05-2013, 05:45 PM   #1
Mex5150's Avatar
Location: To the left of your body, to the right of your mind, lost in a riddle.
Send a message via Skype™ to Mex5150
Default Yurt Design Software?
Hi all,
Completely new to yurts, but my wife says she has always wanted one, so like the fool I am I agreed to build one.
Can anybody recommend software to design the yurt (the actual yurt itself rather than what will go in it like the only other software thread I could see here)? Linux native software would be preferred, but no real problem if not as I can run it under WINE or on a virtual machine.
Thanks.
~Mex
Mex5150 is offline   Reply With Quote
Old 04-05-2013, 05:49 PM   #2
Default Re: Software?
How about these?
CYCAS CAD 2D + 3D + ARCHITECTURE
Sweet Home 3D - Draw floor plans and arrange furniture freely
Or more intense:
RibbonSoft - What is QCAD? (they have a free community version)
frontierjeanne likes this.
Old 04-08-2013, 06:30 AM   #3
Default Re: Yurt Design Software?
Check
Laurel Nest Yurts
website. Hal put out a yurt making manual. Lots of info.
DMac is offline   Reply With Quote
Old 04-11-2013, 09:42 AM   #4
Mex5150's Avatar
Hi CYCAS looks just the job, thanks
Old 04-13-2014, 06:46 AM   #5
You could google 'Simplydifferently.org he has/had a calculator on it. I amnot sure if thats exactly correct or no, google it and they might correct it if its not.
Where do you want to build yours?
Old 06-22-2014, 11:29 PM   #6
I used the calculator on "Simplydifferently.org" and it worked perfectly. There is a bit of a learning curve....it is in metric and some of it isn't very intuitive, but work your way through...you'll be glad you did.
AbbieX is offline   Reply With Quote
Old 06-23-2014, 03:29 PM   #7
Mex5150's Avatar
I was after something a little more advanced, but good find anyway thanks.
I'm British so quite happy with either measurement system :^<
Only had a quick look, I'll go through it more deeply when I get the time. Thanks for the heads up.
Old 06-29-2014, 02:01 PM   #8
I was searching long and hard for a computer tool and the simplydifferent one is the best, mine still has all of the measurements etc. that I worked out on it.
Old 08-02-2014, 04:15 PM   #9
Simply Different is an incredible tool/resource site!
Sara is offline   Reply With Quote
Old 09-05-2021, 01:48 PM   #10
Im in the same boat and looking too for 3d software to desing a round house.
So far haven' t found anything as most is for square design.
Im now using paper in scale, but digital is far easyer.
Also running linux.
Anybody a good working solution that is not to difficult to get going.
yurt plans
