Woodstove In Yurt
Old 09-26-2015, 12:47 PM   #1
Default woodstove in yurt
Hi all
we put up our yurt in the spring & are now getting ready for fall/winter.
I was gifted a woodstove - about 30 years old, but barely used in a condo of old folks. from denmark.
planning on putting it in the yurt, but don't know a lot about wood stoves. I've been over on the hearth.com site & can't find much out about it other than it is probably a hwam.
any thoughts/concerns you could see in installing in our 24' pacific yurt?
thx.
Old 09-27-2015, 10:48 AM   #2
Default Re: woodstove in yurt
I would install it through the wall if I were you, not the roof. A lot less of a chance of it causing a leak that way. Here is my adventure in putting up a chimney and my first wood stove:
And then upgrading to my latest wood stove:
http://www.yurtforum.com/forums/yurt...-yurt-933.html
mama23 likes this.
Old 09-27-2015, 03:49 PM   #3
Jafo. Did you ever post the results/impression of your new 700 lb soapstone stove with the listed 10-12 burn time?
mama23 likes this.
Old 09-28-2015, 08:04 AM   #4
I haven't yet because it really has not been cold enough to do a good test. I can say that we did use it last weekend and it cooked us. I had to open the
lol. It was only 40 degrees out though.
mama23 likes this.
Old 10-09-2015, 09:07 AM   #5
It's juuust about nippy enough at night to fire the stove. Right after halloween is the usual start of yurt
for me at 6500 feet.
Old 10-09-2015, 09:13 AM   #6
We are heading up to the yurt for three nights today. It is supposed to get into the 30's, so we will definitely be trying out the stove!
mama23 likes this.
Old 10-11-2015, 07:01 PM   #7
We have a vintage cast iron stove in our yurt and so far we've been happy with it. This winter will show us if it's really enough.
mama23 likes this.
Old 10-14-2015, 02:10 PM   #8
I have a question about a chimney. How do you make a hole in the wall for it. How far should it be from the wall? Can someone share plans and pictures of existing set up?
Kochevnik
Old 10-14-2015, 02:11 PM   #9
Here's a good thread to start in.
Old 10-14-2015, 02:12 PM   #10
Dough!!!! Thank you, I apologize for double topic
