Heating While No One Is Home?
Old 01-08-2015, 08:39 PM   #1
Default Heating while no one is home?
Hello all,
I was wondering what the recommendation was for
while no one is home. My husband and I are away from home an average of 50 hours per week. We live in upstate NY and need to make sure any plumbing we install will not freeze. A wood stove will be great while we are home, but what can we use to safely heat while we are gone? I know juicy maters suggests radiant heat flooring, but we want to build a platform/deck, so we won't be on concrete slab. Any thoughts from people yurt dwelling year round?
Thanks!
Old 01-09-2015, 09:47 AM   #2
Default Re: Heating while no one is home?
Karl uses a backup propane heater:
https://littleyurtontheborderlands.w...-is-flying-by/
That would probably be my recommendation too..
Old 01-09-2015, 10:14 AM   #3
Excellent, thanks Jafo. I have only lived in conventional homes so I worry about propane heaters spontaneously combusting while we sleep. (I might be slightly paranoid)
Are they safe? I read someone that some heaters release CO into the home? Are those the butane ones?
Old 01-09-2015, 10:46 AM   #4
If vented properly, they are no more risky than an oil furnace (same applies to oil furnaces).
Also, you wouldn't be using these all that often. Your wood stove will keep the house pretty warm for a long time. Of course, you could look at a new wood stove, like a Blaze King KING wood stove that boast a 40 hour burn time. Even if that is half true, it would be good enough for you guys.
dlhall likes this.
Old 01-09-2015, 01:39 PM   #5
The piping/slab of a radiant floor
system can definitely be installed on top a conventionally framed wood floor system that is designed for the extra load. I'm a pro carpenter and have seen it many times. Radiantant is very expensive in comparison to conventional forced air/ woodstove/ propane/ other. However I can tell you the heat radiating from that slab is unmatchable for comfort. If you have the cash it is totally worth the expense.
Old 01-09-2015, 09:36 PM   #6
There is also a metal plate that is screwed to the under side of the wood flooring and it has groves where the plastic pipe is driven into and then insulated under neath not as good as a slab but it works.
klhandler likes this.
Old 01-10-2015, 12:00 PM   #7
It depends on how well-insulated you are. I heat with wood and leave for work 8-10 hours each day. If I shut the stove down before I leave for work the yurt is fairly reasonable when I get home (45 degrees or so most days). On the ten hour days it's a little colder but if you have a good bed of coals then it's pretty easy to heat it back up.
We've already seen -20 this year in my neck of upstate NY. On those extremely cold days I won't hesitate to leave a backup kerosene burner running on low while I'm away. I've heard from multiple sources that they are actually a pretty safe. I've only had to do this a few days this winter.
My yurt is temporary though so plumbing and radiant slab flooring aren't worth the time and money.
One problem I do have with this system: If I'm away for a day or two, or even spend the night away from home I come home to a frigid space the next day.
Old 01-10-2015, 12:50 PM   #8
Where you from in upstate NY? I am near Boonville..
Old 01-10-2015, 03:44 PM   #9
I'm sure the Kerosuns etc. must be reasonably safe while occupants are away, or they likely would be out of business due to lawsuits. The common residential propane/natural gas forced air heating furnaces regularly cycle on during the day with occupants away with no issues, and those flames in the box are HUGE.
Old 01-11-2015, 10:32 AM   #10
The piping/slab of a radiant floor heating system can definitely be installed on top a conventionally framed wood floor system that is designed for the extra load. I'm a pro carpenter and have seen it many times. Radiantant is very expensive in comparison to conventional forced air/ woodstove/ propane/ other. However I can tell you the heat radiating from that slab is unmatchable for comfort. If you have the cash it is totally worth the expense.
Thanks Bob. I did not realize that is an option. Extra cash is one thing we are pretty low on. If propane heaters are safe to be left alone all day, I might consider that as the best option for us. Or, as Jafo mentioned, a larger, longer burning stove.
